Message 1 of 8
BT smart hub 2 proxy issues
Hello,
We have rececntly upgraded to the smart hub 2 and ever since i have not been able to upgrade my windows 10 PC. I tried reusing the old hub and that seemed to repair the issues, but its not a sustainable fix. When using the troubleshooter the error message says "Windows could not automaticaly detect this systems proxy settings"
Please help, thanks
7 REPLIES 7
Message 2 of 8
Re: BT smart hub 2 proxy issues
have you turned of smart setup
Turn Off smart setup
Message 3 of 8
Thanks for your response, yes smart setup is off
Message 4 of 8
I still have the problem
Message 5 of 8
Try a factory reset of the hub, bear in mind that this will re-enable Smart Setup and you will need to turn it off again
If you found this post helpful 🙂 then please let me know by clicking the thumbs up button below. On the other hand, if you found it unhelpful 😞 then please let me know by clicking the thumbs up button below . 😄
Message 6 of 8
Ive factory reset the hub and dissabled smart setup, I still have the problem
Message 7 of 8
Hi,
This could be a problem with you Windows 10 settings. I’ve noticed some browser add-ons add proxy settings under “Control Panel – Internet Options – Connections – LAN settings”.  Check to see if the Proxy Server is set and, if so, uncheck it.
Hopefully this will be the problem.
Message 8 of 8
Can you get online with your Windows machine? if not then try the following
Right click on the Windows start button
Click Run
Type CMD into the box that appears; [hit enter]
In the black window which will appear, type (or copy and paste) ipconfig /renew; [hit enter] (without the semi-colon or anything after it)
