mordred1973
Message 1 of 3
BT wifi extender
I habe purchased a bt wifi extender and it has linked fine with an existing network.  However, it only has a data signal in some of the mains sockets in the house and most importantly not in the ones adjacent to the Youview box it was needed for!
The house is only 7 years old so it shouldn't be anything to do with wiring, does anyone habe any suggestions?
2 REPLIES 2
Message 2 of 3
Re: BT wifi extender
If it is working OK in other sockets it has to be a problem with your sockets rather than the Powerline adaptor. Are the sockets that you are not getting a connection RCD sockets or are there any RCD sockets in the ring main prior to the socket that is not working?
mordred1973
Message 3 of 3
Alll the sockets in the house are the same, they all came from the same supplier at the same time and were all changed (for appearamce) when we bought the house. Seems very strange although they are all down one side of the same room.
I guess the only option will be to change one for another and see what happens
