sveta1978
Newbie
Message 11 of 14
Re: BTHUB6 wireless connection to Sky on demand box
Thank you thank you thank you!!! saved me from having to call useless bt customer services!
bayardmm
Message 12 of 14
I tried this but the IP assignment didn’t change, it remained DHCP
Message 13 of 14
If you changed it on the HUB it will use DHCP, a router can't allocate a 'static' address it can only allocate a 'reserved' address still using DHCP to do so. I.e allocate a given MAC address the same IP address each time. If you want to allocate a static address you need to do it on the device itself as posted in message 2. Give the device an address outside of the DHCP range of the hub.
Nigel3
Newbie
Message 14 of 14
Tried this but I cant see Sky Wireless Connector listed, just some other known devices and a few "unknowns"
