Newbie
Message 1 of 3
BTHub 5
I've been using a BTHub5 now for a number of years, do I need to change the wireless password/key periodically for security reasons? Is the password issued with the Hub unique to that device?  Thanks
2 REPLIES 2
Message 2 of 3
Re: BTHub 5
You only need to change it if you feel you need to. It is not a requirement although good practice to change it from the default one found on the label. Yes, the password on the label is unique to that device.
Newbie
Message 3 of 3
Re: BTHub 5
Thats great, many thanks
