Chilling_T
Message 11 of 11
Re: BTHub6 Can't connect to Smart Life Devices
Hi, after a lot of messing with the home hub 6 . all you have to do is turn the Mode at the bottom of the wifi settings to "Mode 2" compatibility one and it works fine . you might also have to split the 2.4 and 5ghz but all smart life apps work now . Note this does turn of 'ac'network connections.
Save you buying a new router
Tags (1)
