Message 1 of 4
BTWifi-X or BTWi-fi to which do I connect?
BT’s help page on BT Wi-Fi app says to connect to BTWi-fi.
I have additionally ‘found’ in BT’s Wi-Fi app a connection profile, which I downloaded and installed and can connect to BTWifi-X with it.
Both of the above ways to connect work for me.
However why the two methods?
Are BT moving from one Wi-Fi name to the other?
3 REPLIES 3
Message 2 of 4
Re: BTWifi-X or BTWi-fi to which do I connect?
BT WiFi-X is only available when connecting with an iPhone and is the preferred method if you have an iPhone.
Message 3 of 4
Thank You for the reply.
BTWifi-X works on my iPad as well.
Where is this information documents in BT’s FAQs or help?
Message 4 of 4
An Internet search of BTWifi FAQ came up with this which does not mention BTWifi-X
Get wireless Internet | Find wi-fi hotspots | BT Wi-Fi (btwifi.co.uk)
There is no specific page about BTWifi X
