simkinp
Message 1 of 2
Batch execution of speed test utils
Does anyone know if (or how) I can run the http://www.speedtest.btwholesale.com speed test utility from command line, Linux, python etc and return the data to a log file
I’m currently tracking our line using the ookla equivalent because the stability of our line is terrible (and also all of our neighbours have the same issues!)) just thinking that BT might take more notice if I used the BT one instead
1 REPLY 1
Message 2 of 2
Re: Batch execution of speed test utils
BT will only take notice of the BT Speed test.
If you and your neighbours are experiencing problems you would be better to post what the problems are and include as much detail as possible. If you do that you may be able to get assistance from the forum in resolving the problem.
