Message 1 of 3
Black disc connection
I have a hub and one black disc. I need to extend coverage to the end of the garden.  I was just wondering if they work in a chain  (i.e. Hub>>Disc1>>Disc2 as opposed to each disc connecting to the hub) or does each disc rely on direct communication with the hub?
2 REPLIES 2
Message 2 of 3
Re: Black disc connection
Hi, @Adamgw Thanks for posting, yes the discs work in a chain so if they're in range of each other they will extend the wifi around your home.
Cheers
Neil
Message 3 of 3
Nice one, thank you Neil.
