Newbie
Message 11 of 18
Re: Blocked Web Page
Yes I am using a residential connection. I can access on my iPhone if I switch WiFi off, and have accessed from work (which I think is a Virgin connection).
Message 12 of 18
Its a bit odd. Lets do a quick check on the actual connection, as I have recently come across a few of these reports.
What does it say when you click on this link BT Broadband check
its quite safe, my website simply checks on the domain name.
Newbie
Message 13 of 18
It says You are connected to BT Residential Broadband
Message 14 of 18
So you are connected to btcentralplus.com.
There was a recent thread about another site
https://community.bt.com/t5/Connected-Devices-Other/Pinterest/td-p/1800216
Not quite sure what to suggest at this point.
Does it work if you connect to your own BT Wifi hotspot, as that takes a totally different path?
Newbie
Message 15 of 18
Yes it does - I connected via BT Wi-Fi with FON. Very strange.
Message 16 of 18
It takes a totally different route.
Did you read the other thread?
You might like to try a few changes of IP address. You can do this without restarting the home hub. There is a "disconnect" option on one of the screens, where you can just disconnect the PPP session, wait a minute, then reconnect again. You should get a different public IP address.
Newbie
Message 17 of 18
Yes I did. I'll try the options you suggest...at least I can get to the page from here albeit with a bit of messing around. Many thanks for your help, much appreciated.
Message 18 of 18
You must have found a good route now. There must be a faulty router in the network somewhere Smiley Sad
