vinyltapped
Message 1 of 14
Blocked url's/whitelisting
I've recently come to BT broadband from Sky and there is one particular site (wholesaler) I always use as working from home  that is continually blocked i.e. connection time out. I can access the site from my mobile using 4G  but I need to use it from my desktop PC.
I've turned off all parental controls, cleared cache & cookies, flushed DNS and am at the end of ideas.
Any tips/advice out there? BT technical didn't know how to help me and I've seen a topic called 'whitelisting' url pages?
Hellllllp
Tags (2)
13 REPLIES 13
imjolly
Message 2 of 14
Re: Blocked url's/whitelisting
have you also turned of web protect in MYBT as that causes problems
vinyltapped
Message 3 of 14
Yes, I've turned off all the protection from Broadband manage page
vinyltapped
Message 4 of 14
This is the webpage message I get
The connection has timed out
The server at javis.co.uk is taking too long to respond.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
Keith_Beddoe
Message 5 of 14
Try changing the DNS settings on your computer so that it uses Google Public DNS, as it could be an issue with BTs DNS server.
That site is visible on my connection, but I am using OpenDNS not BTs DNS.
Andy_N
Distinguished Guru
Message 6 of 14
Hi, welcome to the forums.
It's working for me on BT DNS.
Are you using any form of VPN?
imjolly
Message 7 of 14
just tried javis.co.uk and came up instantly using bt servers
vinyltapped
Message 8 of 14
Hi, thanks for the reply but I'm not that techy minded re BT DNS and VPN?!
vinyltapped
Message 9 of 14
That's strange?!
vinyltapped
Message 10 of 14
Not sure how to do this?
