ford62
Message 1 of 14
Bolton area having broadband speed problems ???
Been having really slow broadband here in Bolton of late.
Probably been going on for around the last month if i'm right and progressively getting worse. We'd get the odd slow spell and then it would be ok but now after returning home from holiday it has been constantly slow.
Can't see any logged problems with BT.  I've unplugged phone line and router etc to try and reboot them so to speak to no avail.
Any one having the same issues or have advice ?
13 REPLIES 13
Message 2 of 14
Re: Bolton area having broadband speed problems ???
can you post stats from your router
run btspeedtester and then diagnostic test and post results  (been having problems so try IE)
are you using test socket with filter even if you have a filtered master socket?
are you using wireless or ethernet connection when speed slow?
which exchnage and cabinet are you on?
ford62
Message 3 of 14
Hello,
This is wifi speeds i'm talking about.  It's all we ever use in the house now.
Other friends in the area have also said theres is slow to which is making me think it's a BT issue.
How do i post stats ?
Message 4 of 14
when you reply then use 'photo'
wireless problems are normally due to interference within your home or other neighbour's routers on same band  BT and other ISPs do not guarantee speed using wifi for that reason
ford62
Message 5 of 14
Sorry i meant how do i get the stats up ? I know how to post pics on forums etc.
Wifi seems fine again now but i bet when my neighbours return home from work it'll slow again.
Message 6 of 14
if you have hh6 then advanced settings then tecgnical log informtion
if hh5 the troubleshooting then helpdesk
ford62
Message 7 of 14
It's a HH4 I believe
Message 8 of 14
if hh4 are you on copper adsl or if fibre you must have a separate openreach modem
ford62
Message 9 of 14
ford62
Message 10 of 14
The only socket I know of is Master Socket 5C which has an Openreach MIC4 adapter plugged into it
