Message 11 of 14
Re: Bolton area having broadband speed problems ???
that's great
you have a great 17mb connection.  connection time is very short was that due to router dropping conenction or manual reset?
I would suggest you go to wireless in hub manager and split the 2.4/5ghz networks and then add a 5 to the 5ghz network to distinguish which network is which.  you can then log on to either network or both depending on your device.  I would also select the channels manually taking into account the channels in use by neighbours
you can get a wifi analyser app for your mobile which will tell you the channels currently in use near you
ford62
Message 12 of 14
I think it dropped connection it said it was unable to complete this test
Message 13 of 14
the drop has not affected your connection speed which is still good
ford62
Message 14 of 14
Thanks for all the advice. Things seem to have returned to normal some what.
I've not changed anything but i'm certainly a wee bit wiser now regarding wifi , cheers.
