Longshanks
Message 1 of 4
Boosting wifi speed in bedroom
Hi
Have Infinity 1 and use HH2 ( have HH5 but loathe to change current set up which has worked fine until now.
My son plays Xbox one in bedroom and is now complaining that games lagging etc.
I could run another Ethernet but would be a faff. Is there another gizmo I can buy to improve quality/speed of wifi signal in bedroom? Preferably one that is compatible with HH2.
I realise it could be Xbox live rather than our set up but game to maximise speed at our end anyway.
Thanks for you time.
L
3 REPLIES 3
Message 2 of 4
Re: Boosting wifi speed in bedroom
Powerline adaptors. See http://connectedhome.bt.com/product/mini-wifi-home-hotspot-500-kit-powerline-adapter/  you don't have to use BT ones, any make will do.
Longshanks
Message 3 of 4
Ok many thanks. Just out of interest can I check the speed he's getting on his xbox one?
Regards
Longshanks
Message 4 of 4
Done that now. Produces variable download between 5 and 12mb which is higher than the 3mb minimum Microsoft quote.
Will try one of the gizmos and see how much it improves.
Thanks again.
