RichardHors
Newbie
Message 11 of 17
Re: Bowers & Wilkins Speaker Connection
there doesn't seem to be an option to make the 5ghz band name change...?
Message 12 of 17
If its the new  Smart Hub 2, you cannot do it.
http://bt.custhelp.com/app/answers/detail/a_id/56419/related/1
Please note: the Smart Hub 2 doesn't have this capability as it's designed for use with Complete Wi-Fi.
Message 13 of 17
If you have the Smart Hub2, it is not possible to split the bands. A very serious omission by BT in my opinion.
Presumably the screen looks like this.
sh2wireless.jpgPosts crossed
RichardHors
Newbie
Message 14 of 17
Ahhh - yes , smart hub 2 i have. ok one off the list to resolutions to follow. I may try chnage the mode but as we aleady have poor connectiveity despit extra wifi disks i'd rather look for alternative fixes..
RichardHors
Newbie
Message 15 of 17
Hi Again,
I have reset the router factory settings and tried all three modes ...still no connection. The speaker is sat next to the router. i have bounced this one to Bowers & Wilkins as i cant seem to find a solution yet. Thanks for your help to date.
RichardHors
Newbie
Message 16 of 17
Hi,
Thanks for your help today. I have found a solution which was to uninstall the bowers & wilkins installer app and rely soly on itunes airplay to do its thing. Worked a treat in the end but took some getting there !!
Message 17 of 17
Thanks for the update, glad you got it sorted.
