Message 1 of 3
Bridging mode for vpn tunnel
Hi,
I'm having a problem trying to get a draytek 2925n router to see the outside world on the static IP address. I've set the business hub 5 to briding mode but for some reason all I can see on the router is the original IP address 172.16 (setup by me) instead of the BT static address 217.45.
Has anyone got experience on how to correctly bridge the hub5 so the draytek can see the correct address?
One thought I have is to change the setting Static IP address from off to on (this is in the advanced settings) but I'm not sure what this will do to my current network. Does this have to be on for the static IP address to pass through?
Been trying to get this working for a couple of weeks and just banging my head against a brickwall.
Brenden
2 REPLIES 2
Message 2 of 3
Re: Bridging mode for vpn tunnel
Welcome to the BT Residential Customers forum
If you are a business user, please could you post on the BT Business forum at http://business.forums.bt.com/
Message 3 of 3
Hi,
I've done that thank you
