Message 11 of 13
Re: Bridging wired to WiFi networks on SmartHub2
@Preacher wrote:
When the laptop was built, it was on the wire and there were no issues. This is the first time, since it's been on WiFi , that there's been a need to share between the devices.
All new wireless connections are deemed public unless you change the connection type to private. Public connections do not allow file sharing.
Look at the wireless connection properties and see if it says public or private.
Message 12 of 13
Connection in Networking is OK.
However, it seems that, for some reason beknown only to itself, that the Firewall settings within Norton for the WiFi network was set to Public. Changing that to Trusted resolves the issue.
Thanks for the pointer on wherte to look.
Message 13 of 13
As per my reply to @licquorice, they are......
