redls
Message 1 of 15
Broadband Usage Monitor
Just posted this, it appeared then disappeared again! Sorry if this is a duplicate.
The monitor's display was recently altered without warning or explanation and since then updating has been intermittent.
The readings of usage for 1st-24th and 1st to 26th were identical ... 1st to 27th appeared as normal yesterday, then I went on today to find the reading 1st to 26th ... not the same as the previous reading given ...
Checked again 2 hours later, this time the reading was 1st to 27th and was 0.02MB more than the reading given yesterday (I keep a note and compare them with another monitor, makes interesting reading!).  Still no reading for 1st to 28th.
Am I the only one having such problems?
14 REPLIES 14
Message 2 of 15
Re: Broadband Usage Monitor
your post was moved to bills where there are numerous other posts
redls
Message 3 of 15
But this had NOTHING to do with billing.  It was about the poor performance of the monitor which you have done nothing to addressQ!
Message 4 of 15
it is a billing matter as those who go over usage get charged for over usage
redls
Message 5 of 15
But again, my question is about problems with the MONITOR not updating or repeating the same data  3 days apart and THAT question has been totally ignored by it being placed with Bills
Message 6 of 15
There is an existing thread already, that is why you are probably being ignored.
http://community.bt.com/t5/Bills-Packages/Usage-Monitor-not-updated-since-23-59-01-01-2013/td-p/7337...
redls
Message 7 of 15
Thank you for that useful information ... I had a look ... 32 pages! This forum does not make it easy for people to find out if they have a problem or if it is shared ... I didn't even find that thread when I did a search,  before posting my question, so that was very kind of you. Thank you.
Message 8 of 15
The forum search is not always very helpful, and sometime misses single postings.
Guru
Message 9 of 15
The search is pretty bad.  Along with many other forums.
If you want to search this forum for 'xxx', try a google search for 'inurl:community.bt.com xxx'  (and similarly for other forums or sites with bad search capabilities)  Not guaranteed to get the best results either, but probably better than the site's own search.
Message 10 of 15
search like most searches is only as good as the accuracy of the criteria that you enter
