bbbill999
Message 1 of 5
Broadband and web browser
O no another pop up from bt
i have to switch web web browsers to foxtrot or google... I have a sense of comfort with Microsoft , and bt are forcing a change...
It seems to me bt don’t listen don’t care and don’t give a monkeys.. with their latest price increase I’m off... I just don’t get it...perhaps they are trying to fill their black hole of a pension fund with our money???
4 REPLIES 4
Anotheruser1
Message 2 of 5
Re: Broadband and web browser
Microsoft has replaced internet explorer with their new super fast browser called Edge. Although this is only the case for Windows 10. Edge is not available via windows 7 / 8 and i urge you to ensure your not getting blocked by your firewall. Also make sure BT parental controls are turned off. This is known to cause havoc with explorer.
If you want to run Edge on a Windows 7 / 8 machine you will need to use a VM with Windows 10 loaded. Microsoft site has these. VM ( virtual machine)
bbbill999
Message 3 of 5
Thanks.  I’m using micro 10 but will check the  other points thanks
Distinguished Expert
Message 4 of 5
BT is not forcing you to change browsers on Windows 10.
The choice of browsers is yours.
bbbill999
Message 5 of 5
Hi BT did say change or else, it was a pop up. Seeing others had problems it seems I hadn’t loaded edge. That’s now done
Two things if anyone can help
How do I migrate all info on internet explorer to edge?
And
I would like to download my outbox in its entirety to outlook. I have it for my incoming but not my outgoing.
When I do it, I want to KEEP myoutbox intact on bt and not delete them ( this happened a few years ago as outlook is programmed to auto delete) Ideas 🙂
