syfer1987
Message 1 of 9
Broadband cable grey end help need a longer wire can some help me find one
Hi, I have bt hub 5 and i am on the fiber plan. I have "Broadband cable grey end" on this pdf link https://btsupport.custhelp.com/ci/fattach/get/5215084/1516096319/redirect/1/session/L2F2LzEvdGltZS8x...
in here it said it was Broadband cable grey end but Is a way to short. I would like to buy a 5m wire can some help me find one or tell me a way that I can buy one. Thanks
8 REPLIES 8
Message 2 of 9
Re: Broadband cable grey end help need a longer wire can some help me find one
Search for "rj11 extension cable", there are plenty to choose from.
Sage
Sage
Message 3 of 9
You can get RJ11 cables of various lengths from a well known auction site.
syfer1987
Message 4 of 9
Hi would this work
10m-metre-RJ11-To-RJ11-Cable-Lead-4-Pin-Gold-ADSL-Router-Modem-Phone-Black-Long - **Edited**
robby2k9
Message 5 of 9
Take a look at kenable - Home/Computer Cables & Peripherals/ADSL & RJ11 Cables. The good quality ones are marked ADSL2+ and are made from top quality twisted pair cable. Various lengths up to 20m in black or white. That's where I got my 5m one from.
syfer1987
Message 6 of 9
I don't see them at Amazon. Can you mebe post me link to were i can buy from. I would like to buy from Amazon.
syfer1987
Message 7 of 9
Hi i found this one 5m ADSL Cable High Speed BT Broadband RJ11 Modem Router and it is a white cable from Amazon. The name suggests it for bt. So i might get this one what do you think?
Zurdo
Message 8 of 9
We’re not supposed to post links to commercial companies but if you go to your preferred retailer and type ‘RJ11 cable 10m’ in the search box you’ll find loads.
Or remember - Google is your friend!
robby2k9
Message 9 of 9
If possible you should buy a cable that's made to CAT5e spec. especially if you want a long one. The cheap ones supplied with routers are frequently made of cheap straight 2 core wire & are more prone to picking up interference.
