Message 11 of 14
Re: Broadband drops, and Wifi poor, BT Hub 5
That seems a good result
did you remember to turn off smart setup?
Message 12 of 14
Hi imjolly, what do you mean "did you remember to turn off smart setup?"
I plugged it in and everything works fine - not sure what smart set up is, why I would need to turn it off or how I would do that!  Please explain?
Message 13 of 14
Does anyone else know what imjolly means?
Thanks.
Message 14 of 14
this explains and if you read some forum posts it is recommended to turn off smart setup as it causes connection problems
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
