SharonDT
Message 1 of 3
Broadband is working via Ethernet but WiFi isnt
I can access the internet on my PC which is connected by an Ethernet Cable but I cannot use WiFi,  I go onto any mobile device, phone, laptop, ipad and none of them are connected by wifi.  When i got into setting, My BT wifi isn't on display. Has anyone else experienced this?  Thank you
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: Broadband is working via Ethernet but WiFi isnt
@SharonDT
Welcome to this user forum.
If you cannot see the wireless signal from the home hub, then it may be faulty.
Try a factory reset of the home hub and see if the wireless signal returns, If not, then you will have to ask BT for a replacement home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
SharonDT
Message 3 of 3
Thank you Keith, I will try that now
