keithp
Message 1 of 15
Broadband keeps dropping - reset smartbox?
Ok - we have had BT broadband since 2014 at a new build - no issues at all. A few weeks ago it started to drop every so often - maybe once a day - but came back straight away. At the same time there were issues with our local area - the Cayton area. After about five or six calls I received various bits of advice - reset the phone line; five dropouts a day is normal; and now reset the channel on your smartbox.
I have read the manual and it says keeps the box to auto and allow it to choose the right channel, so I am unsure what to do. If up to five droputs a day is normal, well thats that, but if that is rubbish, then perhaps changing this channel moght help.
Has anyone any advice? Also how easy is it?
Keith
14 REPLIES 14
imjolly
Message 2 of 15
Re: Broadband keeps dropping - reset smartbox?
five drops in iternet connection daily is normal and is indicative of a fault - could be internal wiring, socket, hub or external
try quiet line test  dial 17070 option 2  should be silent and best with corded phone
are you using test socket with a filter to see if that improves stability
can you post stats from hub  if hh6 then advanced settings then technical informaion
if hh5 then troubleshooting then helpdesk
you can change wireless channel  http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
keithp
Message 3 of 15
Thanks.
Line has been checked and is ok.
No idea how to the rest - and no idea what a test socket is! However it is a new bungalow, so the socket is new.
imjolly
Message 4 of 15
Test socket is here depending on type of master
stats just follow previous instruction
keithp
Message 5 of 15
Tech info:
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084319+NQ74303639
Firmware version:
SG4B1000D038
Firmware updated:
30-Sep-2018
Board version:
1.0
Gui version:
DSL uptime:
4 Days, 20 Hours 26 Minutes 9 Seconds
Data rate:
19.49 Mbps / 57.41 Mbps
Maximum data rate:
20670 / 58527
Noise margin:
6.9 dB / 6.1 dB
Line attenuation:
17.9 dB
Signal attenuation:
0 dB / 17.9 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
366 MB Uploaded / 2929 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-FGZ5
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-FGZ5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:39:EE:56:A8:57
Software variant:
Boot loader:
9.2.0
imjolly
Message 6 of 15
you have a 57mb connection speed on an attainable speed of 58mb and noise margin normal at 6db  you have also been conencted for 4+ days without any drop in conenction - stats and connection looks ok
is it your wireless conenction that is a problem?  drop internet connection on wireless device yet hub light still blue?
licquorice
Message 7 of 15
Try choosing a different wireless channel, despite what the instructions may say, auto is not the best option.
You could also split the 2 bands http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
keithp
Message 8 of 15
It is a wireless connection, and the lights remain blue even when the connection drops.
licquorice
Message 9 of 15
In which case it is a wifi problem not broadband connection.
imjolly
Message 10 of 15
Then you need to try the suggestions by @licquorice to see if that solves problem. You can also try changing the wireless mode from 1 to either 2 or3
