Message 1 of 3
Broadband
We recently had an outage that has been fixed but my security system panel is showing a “modem fault”.  It’s a pyronix euro 46 and on other outages as always reconnected. Will it sort itself out or should I call an engineer
2 REPLIES 2
Message 2 of 3
Re: Broadband
have you checked your security system troubleshooting  for 'modem fault' to see if fix?  have you contacted your security company to see what they suggest?  is you BT broadband working ok and wifi devices connecting?
Message 3 of 3
Re: Broadband
Thanks for that, I’m not brave enough to be the engineer so looks like a call out. Still worth a punt.
