johnctemple
Message 1 of 8
Browsers freezing intermittently
After browsing for a spell, all my browsers freeze and I need to restart which usually solves the problem. However, it is extremely irritating. Any ideas how I can stop this happening or what is causing it?
7 REPLIES 7
Message 2 of 8
Re: Browsers freezing intermittently
Biggestted
Message 3 of 8
I've been experiencing the same issue for the last 2 weeks. Do you use BT virus protect or a Mcafee security software?
Check out the link as gg30340 posted.
Distinguished Guru
Message 4 of 8
I used to get that issue with IE. Switched to chrome and now all OK.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
johnctemple
Message 5 of 8
Many thanks for the replies. I have now uninstalled McAfee BT Net protect Plus and installed Avast. They want me to pay £1.50 per month for their Premium service but I havent down that. Is it necessary? I will let you know how things go.
Message 6 of 8
See the other thread you have posted on.
johnctemple
Message 7 of 8
My browsers are now working much better and dont freeze. Google chrome often has unresponsive pages though. Would I benefit by deleting the programme and re-installing Google Chrome?
Message 8 of 8
It wouldn't do any harm so worth a try.
