rshah77
Newbie
Message 1 of 5
Bt Home Hub Virtual Server
So I've been trying to look around and all around the config of the BT Home Hub and can't seem to see anywhere that I can set up a virtual server. Does anyone know if the hub offers this and where I could find it/ set it up from?
Any help is appreciated 🙂
4 REPLIES 4
Liam_
Expert
Message 2 of 5
Re: Bt Home Hub Virtual Server
For port forwarding or putting a device on the DMZ you would need to go into the Advanced Settings, Firewall and adjust the settings there.
rshah77
Newbie
Message 3 of 5
Yep found out to resolve this I have set up a virtual machine that uses a separate WIFI adapter and created a port forward for it. Just really wish BT would make some options a bit clearer in the way to go about it 🙂
Liam_
Expert
Message 4 of 5
Indeed, the 'Manual' is distinctly lacking in detail.
smf22
Recognised Expert
Message 5 of 5
If we want to talk about clarity, then the original question has to be a candidate. I read this as wanting the Home Hub to host a virtual server Smiley Very Happy
Not a mention of port forwarding. Kudos to you understanding that.
Regards
