tintac
Message 1 of 4
Bt Whole Home Wi-Fi
System seems to have given up with me and getting a bit fed up resetting the discs (white) and so on. My question might be a bit silly. Three discs, three daughters living elsewhere. If I were to give them a disc each would it work for them then I wouldn’t be wasting £175. Thanks.
3 REPLIES 3
albertj
Recognised Expert
Message 2 of 4
Re: Bt Whole Home Wi-Fi
In short, no.
There wouldn’t be a whole lot of point unless they also have the same white disks. You have to have a disk connected to your router, so then they would just have two Wi-fi; one from the router and the disk. So they’re wouldn’t be a lot of point.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Keith_Beddoe
Message 3 of 4
I suppose they could connect the disk to the router using a long Ethernet cable, or powerline adapters, and simply use it as a wireless access point in a different part of their house.
tintac
Message 4 of 4
That makes sense apologies for being a bit stupid. Thanks.
