Hello guys can anyone advise me on bt broadband extenders.
currently I'm working with a pair of 500s and all is working well. However my problem is this I purchased a new pair of 600s and when I set up both pair won't won't work together.
one has to be disabled to allow the other free run.
i have to top bt broadband installed so it should have a problem coping with the download.
I worked till I'm exhausted setting and resetting green lights on etc etc. Have I missed something?
many thanks for your help .
barry
Solved! Go to Solution.
You can only have one set of adaptors connected to the home hub.
This page will help Important - Using powerline adapters or broadband extenders
You may be able to slave one of the 600s to the master 500s, but you could not use the master unit from the 600 set.
