dazzarfc12
Message 1 of 10
Bt fibre
I seem to be getting disconnected alot my xbox runs slow in get cut off when ever it wants videos don't play properly on facebook am paying for fibre it's terrible
9 REPLIES 9
Message 2 of 10
Re: Bt fibre
post stats from your router
check quiet line test  dial 17070 option 2  should be silent and best with corded phone
are you using test socket with filter?
are you using powerline adapters
Message 3 of 10
Re: Bt fibre
Is your xbox connected to the home hub using a wireless connection, or an Ethernet connection?
Wireless is likely to be very unreliable and can be very slow.
Unless you are on FTTP, you are only paying fror a copper connection from a fibre cabinet, so its not really a true fibre connection.
dazzarfc12
Message 4 of 10
Re: Bt fibre
Yes Xbox is wireless my room is also in the loft and my router is down 2 flights of stairs but even when am down stair facebook videos don't play properly
Message 5 of 10
Re: Bt fibre
Take the xbox downstairs, and plug it directly into an Ethernet port on the home hub, that will prove whether its a wireless issue.
Use the LAN port on the xbox and turn the xbox wireless off.
dazzarfc12
Message 6 of 10
Re: Bt fibre
What if i run an Ethernet cable from the room to the router
Message 7 of 10
Re: Bt fibre
You could try that, even if its just on a temporary basis to prove the problem. Long Ethernet cables are not expensive.
The other option would be to try broadband extenders (Powerline adapters), but they can also give problems. Try a cable first.
dazzarfc12
Message 8 of 10
Re: Bt fibre
Ave always had problems with it bt and sky when I just had normal broadband speed the router used to cut off and reset but I spoke to a guy from virgin media at work and asked him if he knew about this problem and he asked who I was with told him he said it will be the copper they don't change it and I stay in pritty old houses so my copper will be in bits
dazzarfc12
Message 9 of 10
Downloading on xbox
Hey i posted earlier about my Xbox disconnecting every maybe hour or so and slow downloads is this because am so far from my router
Message 10 of 10
Re: Downloading on xbox
as from what you have posted you are conencting using wifi then yes the distance between your device and hub will be a problem especially if 2 floors up  for gaming should always use an wired conenction for best results
