Message 1 of 4
Bt full fibre
Hi
I currently have a mk2 box and going to full fibre will I have to use a cat5e cable to connect to router or can I use existing cables
3 REPLIES 3
Message 2 of 4
Re: Bt full fibre
Anything less than cat 5e cable is not rated for 1Gbps. Your choice.
Message 3 of 4
Re: Bt full fibre
When you move to full fibre your existing sockets and wiring are redundant.
The fibre will terminate on a new ONT (optical modem) which connects to the hub via an Ethernet cable.
Message 4 of 4
Re: Bt full fibre
But there will still need to be an ethernet cable between the ONT and the router/smarthub. Cat 5e cable should be OK, but I would be inclined to upgrade to Cat 6 - these cables are available quite cheaply on Amazon.
