mrtilly
Message 1 of 5
Bt hub 3
my Bt hub 3 drops the wireless signal hower all the lights on the hub stay blue. If I reboot the hub I get a signal, BT say line is fine but can send out an engineer. They explained there could be a cost if no fualt is found or it's my wiring, I don't have any thing attched to the hub. I asked about a replacement hub, NO. So looks like I will have to buy my own hub to see if that sorts out the problem. I have also tried factory reset.
4 REPLIES 4
Message 2 of 5
Re: Bt hub 3
Possibly a router issue.
You can buy decent routers for not much money, and given the age of the hub 3, they'll be far superior.
mrtilly
Message 3 of 5
Re: Bt hub 3
thanks
mrtilly
Message 4 of 5
Re: Bt hub 3
follwing another check by BT a fault was found on the hub and it was replaced with a new hub 4. To date no drop outs
Moderator
Moderator
Message 5 of 5
Re: Bt hub 3
Thanks for the update @mrtilly.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
