Dodgydave61
Newbie
Message 1 of 4
Bt hub 4 changing channels in manual mode.
My hub 4 keeps changing channels in manual mode, but only on the 5Ghz band, when i set it to say 54,56, 58 60, or 100, after say 3 or so days it changes to 38 Always, and it's doing my fkn head in, . The 2.4g band is ok it never moves.
Why is this happening???
3 REPLIES 3
Message 2 of 4
Re: Bt hub 4 changing channels in manual mode.
Have you tried a factory reset by pressing recessed button on back and holding 20/30secs until lights flash
Dodgydave61
Newbie
Message 3 of 4
Yes i have reset it, and it still keeos doing it, my next option is to buy a Netgear router if this can't be solved.
Message 4 of 4
If you have tried factory reset not just a reset and problem persists then sound like hub faulty. As long as you are still in fixed term contract then phone 151 and request a replacement
if you are buying third party modem/router tplink is popular on the forum
