Xemnes
Message 1 of 10
Bt hub 5 wifi connectivity issues constantly
hello, i hope to get some help as this is driving me crazy... my parents are quite dismissive of the problem and tell me to leave it alone so id thought id seek help from people who knew more about my issues and hope to help me solve them.
basically, initally our problem was the smart wireless was causing our apple devices to not be able to connect so i turned it off. this was fine for a while until the hub updated to 4.7.5.1.83.8.204 (which is aparently the latest for type A hubs). now the 2.4ghz band will constantly freeze all day making only the 5ghz band usable but apple devices in the household wont stay connected tothe 5ghz band. ive tried everything to make the 2.4ghz band consistently usable but nothing seems to work, the connection issue persistent even after a restart... changing the channel does absoutely nothing...
having to restart almost feels like a chore in itself due to how slow the hub 5 takes to restart, im assuming this is because of the dual band wireless.
i hope someone can help with this problem.
thanks
9 REPLIES 9
Xemnes
Message 2 of 10
Re: Bt hub 5 wifi connectivity issues constantly
Still need help with this issue
Message 3 of 10
so is your internet connection ok and stable just a problem with your 2.4ghz wifi?  if so did you try a factory reset using the recessed button on the back and holding 20/30 secs until lights flash
Message 4 of 10
The best advice is to buy a decent VDSL modem/router and throw the Homehub 5 in the bin.
If you don't mind having 2 boxes you could buy an Openreach modem from an auction site and buy a third party router with a WAN port and connect that to the Openreach modem.
Either way it will cost about £70 but it will undoubtedly perform better than any of the Homehub set ups and you will not be subjected to software "upgrades" pushed to your Homehub by BT.
ascender
Message 5 of 10
We moved to Business Broadband this week and got a Homehub 5 sent out. Previously I was using an Apple Time Capsule connected to the Openreach modem, but was keen to give HH5 a go. Unfortunately we had the same problems as you with the 5GHz band and Apple devices and our Canon wireless printer wouldn't work with it either. Have now plugged the old Openreach modem in and are back on the Time Capsule - everything is working ok.
I did speak with BT support, but the call quickly went the usual way where they start looking at everything other than the home hub itself and so after a while I just gave up.
Message 6 of 10
Welcome to the BT Residential Customers forum
As you are a business user, please could you post on the BT Business forum at http://business.forums.bt.com/
Xemnes
Message 7 of 10
the internet connection is perfectly fine, we had an openreach man come out to check our line and he gave us a hub 5 and took our hub 3 away which was much better. the guy said that the hub 5 was much better. i have done 4 factory resets using the button and it hasnt done a thing.
Xemnes
Message 8 of 10
problem is if i got a new router to replace the hub, i would have no idea how to set it up. we used to have a hub 3 with an openreach box but our openreach box was faulty which both had been replaced with a hub 5.
Message 9 of 10
If you do decide to buy a decent VDSLmodem/router they are very easy to set up. Some are virtually plug and play and at most require just entering a password and user name which you will get from this forum if you go down that route.
ascender
Message 10 of 10
Lol, ok, if you insist.... * insert confused smiley *
