Message 31 of 62
Re: DNS constantly reverting to 127.0.0.1???
Was there a line that looked someting like 127.0.0.1:53, if so what was under the PID column for that line?
eadmr04
Message 32 of 62
Don't think I'm getting the correct command promt up as nothing like that came up?
Message 33 of 62
@eadmr04 wrote:
Cant seem to type what you've suggested, will this work?  netstat -ano/find ":53"
I cant find the symbol you have between ano and find?
Sorry missed this post. The pipe symbol is the bottom left key on my keyboard shifted \.
Message 34 of 62
You should see something like this
eadmr04
Message 35 of 62
This what I get below?
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>netstat -ano¦find ":53"
Displays protocol statistics and current TCP/IP network connections.
NETSTAT [-a] [-b] [-e] [-f] [-n] [-o] [-p proto] [-r] [-s] [-t] [interval]
-a Displays all connections and listening ports.
-b Displays the executable involved in creating each connection or
listening port. In some cases well-known executables host
multiple independent components, and in these cases the
sequence of components involved in creating the connection
or listening port is displayed. In this case the executable
name is in [] at the bottom, on top is the component it called,
and so forth until TCP/IP was reached. Note that this option
can be time-consuming and will fail unless you have sufficient
permissions.
-e Displays Ethernet statistics. This may be combined with the -s
option.
-f Displays Fully Qualified Domain Names (FQDN) for foreign
addresses.
-n Displays addresses and port numbers in numerical form.
-o Displays the owning process ID associated with each connection.
-p proto Shows connections for the protocol specified by proto; proto
may be any of: TCP, UDP, TCPv6, or UDPv6. If used with the -s
option to display per-protocol statistics, proto may be any of:
IP, IPv6, ICMP, ICMPv6, TCP, TCPv6, UDP, or UDPv6.
-r Displays the routing table.
-s Displays per-protocol statistics. By default, statistics are
shown for IP, IPv6, ICMP, ICMPv6, TCP, TCPv6, UDP, and UDPv6;
the -p option may be used to specify a subset of the default.
-t Displays the current connection offload state.
interval Redisplays selected statistics, pausing interval seconds
between each display. Press CTRL+C to stop redisplaying
statistics. If omitted, netstat will print the current
configuration information once.
Message 36 of 62
As before withe DNS cache flush, I guess you need to right click and run cmd.exe as administrator to get results.
eadmr04
Message 37 of 62
Found it, this is what I get?
C:\Users\Dom>netstat -ano|find ":53"
TCP 0.0.0.0:5357 0.0.0.0:0 LISTENING 4
TCP [::]:5357 [::]:0 LISTENING 4
UDP 0.0.0.0:5355 *:* 1648
UDP 127.0.0.1:53900 *:* 2304
UDP 127.0.0.1:53901 *:* 2304
UDP [::]:5355 *:* 1648
C:\Users\Dom>
eadmr04
Message 38 of 62
C:\Users\Dom>
eadmr04
Message 39 of 62
C:\Users\Dom>
_dreamer_
Message 40 of 62
What, if any,firewall do you have running?
