eadmr04
Message 41 of 62
Re: Bt hub wireless ok but no internet on my PC via Ethernet?
Running windows firewall
eadmr04
Message 42 of 62
It appears to be present on two lines:
UDP 127.0.0.1:53900 *:* 2304
UDP 127.0.0.1:53901 *:* 2304
Message 43 of 62
Did you re-run the command as admin?
eadmr04
Message 44 of 62
Yes I did and got this:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Dom>netstat -ano|find ":53"
TCP 0.0.0.0:5357 0.0.0.0:0 LISTENING 4
TCP [::]:5357 [::]:0 LISTENING 4
UDP 0.0.0.0:5355 *:* 1648
UDP [::]:5355 *:* 1648
C:\Users\Dom>
Make sense?
Message 45 of 62
I just briefly saw a reply from you and then it disappeared!!!! There didn't appear to be any problems with what I saw though, strange.
eadmr04
Message 46 of 62
I keep trying to post but very difficult when I only get about a 30 second window lol. For some reason this site is deleting some of my post which isn't helping 😞
eadmr04
Message 47 of 62
This is what I got?
C:\Users\Dom>
Message 48 of 62
I think 2 threads have been merged, so maybe has something to do with which thread you post on. From what I saw briefly, there doesn't seem to be anything untoward with the results of the command. I'm really out of ideas now other than trying a system restore to a time earlier than the problem.
Edit: Can see the reults again now, all looks OK
Did the problem just suddenly start happening or was it after you had made some changes/downloaded updates/etc
Message 49 of 62
What virus checker do you have? Is it Avast?
eadmr04
Message 50 of 62
Can't remember doing any sort of major downloads? Thanks for all the help though.
