Message 1 of 6
Bt infinity. Atrocious WiFi help !!!
What can I say moved from sky fibre in October and have hand nothing but issues with the WiFi. 50mb download and 10 upload allegedly Sky was unstable but never had to buy WiFi extenders. Numerous calls , router resetting 3/4 times a day How can u get 35 mb and 9 upload and use identical phone straight after and get 1.2 upload.
Bt routers are basically **bleep**. Any advise ? if I could I would jump ship back to sky will keep reporting the service to the point I can leave because it’s total pathetic.
5 REPLIES 5
Expert
Message 2 of 6
Re: Bt infinity. Atrocious WiFi help !!!
Have you turned off smart setup on the hub? Have you split the bands 2.4ghz and 5ghz?
Message 3 of 6
You can also try to change wireless mode in additions to the suggestions of @Zombie
can you post post stats from your hub. Go to advanced settings then technical log information
enter your our phone number and post results remember delete number https://www.btwholesale.com/includes/adsl/adsl.htm
Message 4 of 6
Yes the channels are split but was told the i5 only is if in same room as router , smart set up has been off since day 1
Message 5 of 6
Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High Low High Low
VDSL Range A (Clean) 66.1 48 15.5 10 40 Available -- --
VDSL Range B (Impacted) 54.6 35 13.7 7.1 27.4 Available -- --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 15.5 -- 13.5 to 17 Available -- --
WBC ADSL 2+ Annex M Up to 15.5 Up to 1.5 13.5 to 17 Available -- --
ADSL Max Up to 7.5 -- 6.5 to 8 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 18-01-1970
Message 6 of 6
The 5ghz does cover a shorter distance but is faster and may well cover further than room router is in just need to try and see
are you able to post router stats
