ticuul
Newbie
Message 1 of 4
Bt infinity
Hi, i have bt infinity and i was wondering if i can change my bt hub 3.0 with an asus rt-n66u router. My current router has some issues.. if it's possible can someone tell me how to swap the routers? Thanks
3 REPLIES 3
Message 2 of 4
Re: Bt infinity
Yes, you can use that in conjunction with the Openreach modem.
Message 3 of 4
Re: Bt infinity
Configure the Asus WAN port for PPPoE, username homehub@btbroadband.com, password bt, VLAN 101
ticuul
Newbie
Message 4 of 4
Re: Bt infinity
thank you  licquorice. i'll try that.
EDIT: I did what you said and it's working. Thank you
