Jeffzes
Message 1 of 5
Bt super hub 6
Just signed up. Few questions
On my current isp I have a router than plugs into my pc from the extension socket upstairs the master socket just has a plug on. Do I plug the hub into the master socket downstairs when I get it? That means I won't have a router on my room? I use wifi on my phone but not on my PC
Are the security on the bt hub and the bt virus protect separate? I don't use mcafee so would use my own anti virus as I've read it the virus protect sliws down the browsing?
Does the bt hub need added protection? When I'm surfing wifi will it be safe
Finally do I need to change my default password on my hub so people can't get into it using the general default password
Many thanks
4 REPLIES 4
licquorice
Message 2 of 5
Re: Bt super hub 6
If your current ISP router works how you have it connected , the Home Hub will work exactly the same, its just another router.
Routers don't have anti virus protection/security.
Use your own anti virus.
There is no default password for the hub, each hub has a discrete password which you can change if you so wish.
Jeffzes
Message 3 of 5
Re: Bt super hub 6
Are there any wires to go into back of my pc?
Do I plug the hub into my phone socket upstairs with the pc or the main phone socket downstairs?
imjolly
Message 4 of 5
Re: Bt super hub 6
just use the current cable which comes from socket to your existing router and it should conenct to the dsl socket on the hub  connect the ethernet cable from your pc to 1 of the 4 ports on the hub  connection should be ok  just plug and play
licquorice
Message 5 of 5
Re: Bt super hub 6
Just connect it exactly the same as your existing router, it is no different.
