Message 1 of 2
Bt wifi extender
BT has sent tp-link AV1300 kit as wifi speed needs boosting. The router is on a different mains ring to upstairs in house, so I think it won't work ?
What can be done to boost strength of signal?
Could  we run an Ethernet cable from the plug to upstairs to pair with the other plug in ?
I would be grateful for any advice.
TIA
1 REPLY 1
Message 2 of 2
Re: Bt wifi extender
as the sockets connected to the same consumer unit?  if so they should work
