RadoXX
Message 1 of 7
BtWifi & Openzone
Morning Everyone! Just a quick question, where does this bt wifi hotspots comes from?
Btwifi
Bt-Openzone
Bt-Wifi-X
BtWifi-with-Fon
Does all this hotspots comes from close neighbours router who has broadband on contract,or its comes from somewhere else?
Many thanks for your help.
6 REPLIES 6
Message 2 of 7
Re: BtWifi & Openzone
From neighbours.
RadoXX
Message 3 of 7
Thank you for your reply, The next question is are this wifi hotspots on the same channel? for example in my area there is 4 wifihotspots, but all this 4 is displayed as one when i search wifi on my phone.Correct me if i am wrong.
Message 4 of 7
If you download wifi analyzer app to your phone (assuming Android) you will see what channels they are transmitting on.
BT Expert
Message 5 of 7
Also to add to
BT ExpertJamesC
Show your appreciation!
Kudos”
I am a BT Employee and I am here volunteering my own time to give advice, on technical queries, where I can. Go here for more info.
RadoXX
Message 6 of 7
My question was a bit different. What i was asking for is if i have 5 neghbours in my area using bt broadband, when i scan for wi-fi networks i can see bt wifi with fon only as 1 name. does it means when i connect to wifi it will connect to all 5 neighbours?
BT Expert
Message 7 of 7
You will only connect the same device to one of the BTWifi BSSIDs at a time (your device will usually connect to the one with the strongest wifi signal), so your device will not connect to all 5 at the same time. However if you are walking a distance from A to B which is covered by multiple routers/access points transmitting one of the BTWifi SSIDs then your device may hop between them.
BT ExpertJamesC
Kudos”
