Smartcard
Message 1 of 2
CCTV CONNECTION
Hello..
I sincerely apologise for the intrusion, however I message with regard to my cctv systems.
it is an analogue system simply connected to router via Ethernet cable.
since installation everything has worked well.
3 weeks ago we were sent a replacement router.
since then, mu dvr network diagnostics say:
gateway......ok
network.....err
i have rebooted, turned off and ensured dhcp enabled.
is it the ‘open http port’ inside the router and if so, how do I access the router to open the port?
All responses greatly appreciated.
1 REPLY 1
imjolly
Message 2 of 2
Re: CCTV CONNECTION
if you received a new hub did you turn off smart setup as this often causes problems
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
