dannyr1
Message 1 of 2
CCTV not connecting to Smart Hub
Had the smart hub 6 for over a year now
but I have just installed CCTV the CCTV won't connect.
Has anyone any ideas as I've never had an issue before when changing modems in the past?
I have looked around and followed the BT Guides to set up ports 80. to be "open" but when i check they still say they are closed?
1 REPLY 1
Devon_Dave
Distinguished Guru
Message 2 of 2
Re: CCTV not connecting to Smart Hub
Are the cctv cameras wired or wireless?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
