mburnside
Message 11 of 22
Re: CGNAT and DDNS
Yeah, seems to do the same if I use either manually entered or the mac address actually.
Using port 6200 and 5554 here!
Thank you once again.
mburnside
Message 12 of 22
Re: CGNAT and DDNS
Anyone got any other ideas here?
Guess the port forwarding must be okay as like I said if I restart the DVR it forces the DDNS to go through again.
mburnside
Message 13 of 22
Re: CGNAT and DDNS
A bit more information on this problem.
Just had a customer run a few checks for me.
DDNS service was not working. Swapped the 2nd DNS server for the DVR to 8.8.8.8 and force checked the DDNS name. Service began working as expected.
Customer then rebooted the router to force an IP change and could no longer connect. Force checked the DDNS host name in the DVR and connection could be made again.
Here are the trace results.
TraceRoute from Network-Tools.com to 81.139.135.54 [slackwoodhouse.dvrlink.net]
Hop(ms)(ms)(ms)      IP AddressHost name
  1   0   0      129.250.202.253 xe-0-4-0-12.r01.dllstx04.us.bb.gin.ntt.net
  0   0   0      129.250.2.10 ae-1.r20.dllstx09.us.bb.gin.ntt.net
  34   33   Timed out      129.250.3.50 ae-3.r20.asbnva02.us.bb.gin.ntt.net
  39   35   35      129.250.4.5 ae-0.r21.asbnva02.us.bb.gin.ntt.net
  120   120   129      129.250.2.145 ae-2.r23.amstnl02.nl.bb.gin.ntt.net
  127   125   127      129.250.4.125 ae-0.r22.amstnl02.nl.bb.gin.ntt.net
  119   119   143      129.250.5.197 ae-5.r23.londen03.uk.bb.gin.ntt.net
  121   120   122      129.250.6.55 ae-7.r00.londen10.uk.bb.gin.ntt.net
  131   131   137      82.112.101.74  -
10   142   132   132      166.49.214.197 166-49-214-197.eu.bt.net
11   131   130   131      213.121.193.104 core4-te0-12-0-12.faraday.ukcore.bt.net
12   130   131   129      109.159.249.172 acc2-10gige-0-3-0-2.l-far.21cn-ipp.bt.net
13   131   129   129      109.159.249.237  -
14   150   150   151      217.41.168.108  -
15   140   140   139      217.41.168.146  -
16   134   134   134      213.120.177.101  -
17   131   136   131      213.120.178.148  -
18   158   159   159      81.139.135.54 host81-139-135-54.in-addr.btopenworld.com
Trace complete
Thanks guys!
Message 14 of 22
Re: CGNAT and DDNS
Have you set up the home hub to automatically update your IP address? The facility to do this depends on whether you are using one of the build in services.
mburnside
Message 15 of 22
Re: CGNAT and DDNS
Yeah we're not using the routers DDNS it's a 3rd party DDNS service and we have checked more than 1 service too.
Message 16 of 22
Re: CGNAT and DDNS
It possible that BTs Web address help is upsetting the DDNS host name lookup.
Make sure the affected people are opted out.
http://preferences.webaddresshelp.bt.com/selfcare/
mburnside
Message 17 of 22
Re: CGNAT and DDNS
Can't check this at the moment but is this something assigned to the customers connection? It looks like it affects only the customers PC/browser?
Message 18 of 22
Re: CGNAT and DDNS
It intercepts invalid DNS requests and redircect them to a list of suggested sites. Its done at network level, so will affect all devices connected to the customers connection.
Its know to give problems with VPN connections as well.
mburnside
Message 19 of 22
Re: CGNAT and DDNS
Thanks for that then, I shall give it a go.
mburnside
Message 20 of 22
Re: CGNAT and DDNS
Can anyone at BT assure me that the DNS settings used by dvrlink.net should be fine using BT broadband?
Here is the results from the intoDNS lookup.
http://www.intodns.com/dvrlink.net
Regards
M
