Newbie
Message 1 of 7
Cable to BT Smart Hub 2
Which type of ethernet cable should I buy to my new Smart Hub 2? Just says "Cable with grey end..."s and none of my old yellow cables seem to fit
6 REPLIES 6
Message 2 of 7
Re: Cable to BT Smart Hub 2
ethernet cable fitting is standard  probably cat6 cable
Newbie
Message 3 of 7
Thank you. Is it RJ11? Or RJ45?
Message 4 of 7
If you mean the grey DSL cable that you connect to the master socket rather than Ethernet, it is an RJ11 - RJ11 cable.
Message 5 of 7
if it is cable from hub to phone socket then rj11 but if ethernet then rj45
Newbie
Message 6 of 7
It is from phone socket to Smart Hub so I guess RJ11. Many thanks for your help! Quite cross that BT didn't include the cable in the delivery or at least pointed out which cable to buy... 😞
Message 7 of 7
annica,
How many sockets are there on your 'phone socket? Is it just one, or is it 2, of different shapes?
If just one (like mine), it's apparently *very old*, and I think you have to plug an ADSL filter into it. Out of the ADSL filter there'll be 2 sockets, of different shapes, one called "telephone" and one called "ADSL" (or similar).
If 2, one goes to your Hub, and one goes to your 'phone (if you're using a landline telephone).
I think "RJ11" and "RJ45" refer to the shapes of the little plugs on the ends of the cable, and "CAT5", "CAT6", etc, refer to the quality of the cable.
