trizone13
Newbie
Message 1 of 2
Can BT Smart Hub (HH6) be used just as a modem?
I had a Hub 5 and got a free upgrade to BT SMart hub. I was thinking if this new hub can be used just as a modem as it was not possible with the BT Hub 5?
1 REPLY 1
Message 2 of 2
Re: Can BT Smart Hub (HH6) be used just as a modem?
It is not possible. You should have a read through the forum about the Smarthub. You might want to stick with the HH5. If it ain't broke, don't fix it.
