ahmsajid
Message 1 of 3
Can I ask Openreach engineer to update my Master Socket?
Hi
I moved to Openreach ecosystem from VM. The engineer will come this week to install my new line. So I wanted to know if the Openreach engineer can update my current Master socket to the latest MK4?
Do I need to buy the MK4 socket or the openreach engineer have it with them?
Tags (2)
2 REPLIES 2
JohnC2
Moderator
Moderator
Message 2 of 3
Re: Can I ask Openreach engineer to update my Master Socket?
Hi @ahmsajid, if the socket needs updating then the engineer will be able to complete this on his visit. You would not be required to provide the new socket. We can't give a definitive answer on what will happen so you will need to wait for the engineer visit.
cheers
John
ahmsajid
Message 3 of 3
Thanks a lot for the info. I will wait for the engineer's suggestion. Cheers Mate
