Dc1977
Message 1 of 4
Can I connect 2 hub 5s to 1 master hub 5?
Can I connect 2 hub 5s (Slaves) to 1 master hub 5?
3 REPLIES 3
licquorice
Message 2 of 4
Re: Can I connect 2 hub 5s to 1 master hub 5?
Yes, if you intend using them as wireless access points/ethernet switches. Give each a different IP address outside of the DHCP range of the master hub, disable DHCP on the slaves and connect them LAN port to LAN port
albertj
Recognised Expert
Message 3 of 4
Yes, you can set them up as Access Points to boost your Wi-Fi around your house. You will have to plug them into ethernet though. There is a guide on Google about how to do it, just search 'setup bt hub 5 as access point'. Don't think I can post the link.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Dc1977
Message 4 of 4
Cheers 🍻
