Message 1 of 3
Can I extend reach of the Digital Voice handsets via WholeHome Wifi?
Hi, we moved in recently and still learning about the new fttp. I would like to improve the range of the BT Digital Voice phone handsets and wonder if they use the Wifi and hence could be benefitting from the BT WholeHome Wifi discs we have? Or are they just keyed in to the main SmartHub2 and limited to that. Many thanks.
2 REPLIES 2
Message 2 of 3
Re: Can I extend reach of the Digital Voice handsets via WholeHome Wifi?
@HoarCross
They do not use normal wifi, they use DECT, and the smart hub 2 is the base station. Its not possible to extend the range using the discs.
https://en.wikipedia.org/wiki/Digital_enhanced_cordless_telecommunications
Message 3 of 3
OK, thank you for the quick reply. That's a shame. Will have to look into DECT extenders then I guess?
