Message 1 of 9
Can I move my Smart Hub 6 from one room to another?
Ok so I'll try and give as much information as I know with this. My Smart Hub 6 is located in my hallway as this is where the openreach master socket is.
I want to move it to my bedroom upstairs so I can plug my Xbox One X directly in to the router as I have been having major issues with online lag for months. I have tried all the settings and ports under the sun (but if you want to see if there is something I haven't tried by all means recommend away).
I have a phone line in my room which works with my sky so I'm hoping (but not optimistic) there is some way of using this with the modem but can't figure out how I'd go about it (seriously my optimism is on the floor).
Any help would be greatly appreciated.
Cheers
Chris
8 REPLIES 8
Message 2 of 9
Re: Can I move my Smart Hub 6 from one room to another?
Which master socket do you have as you could connect the particular extension wiring assuming it is directly wired to master by connecting the wires to the data terminals in master
you could also use poweline adapters and leave router where it is
Message 3 of 9
I'll be honest I'm not as tech as I'd like to (or should) be. It is an openreach socket with a face plate on it. Is this what you are asking?
Message 4 of 9
Like one f these
Message 5 of 9
Yeah it looks exactly like that middle picture.
Message 6 of 9
did you consider powerline adapters which would be easier?
Message 7 of 9
It still wouldn't be truely wired. It would just be wired to something that is connected wirelessly. I don't see the point?
Message 8 of 9
Poweline adapters do not use wireless, they use the mains wiring.
See https://www.shop.bt.com/mini-sites/connected-home/broadband-extenders
Message 9 of 9
Just move the 2 wires from the extension that are connected to terminals 2&5 on the removable faceplate of the master to the data extension terminals shown by the yellow arrow in the picture.
