Message 1 of 3
Can I restrict which devices use BT Discs?
Is there a way I can limit which devices in the house are allowed to connect to specific discs?
Looking at the Hub Manager I can see multiple devices connected to each disc. Can I, for example, limit it so that only the kids games consoles are connecting to the disc near their bedrooms?
2 REPLIES 2
Message 2 of 3
Re: Can I restrict which devices use BT Discs?
No, that is not possible.
Message 3 of 3
As has been said, there is no way to do this. But why would you want to do it anyway?
