Paul555
Newbie
Message 1 of 2
Can i just openreach modem
I would like to ditch my BT Home Hub for a UPNP / port forwarding router, as there is no 'modem mode' on BT  i would use an OpenReach modem and attach a Netgear to that.
What is the detail of doing that or is the Openreach modem just a plug a play device. eg: will i have to spend hours on the phone to BT support.
thanks
1 REPLY 1
Message 2 of 2
Re: Can i just openreach modem
The modem is just plug and play. If you get a Netgear VDSL modem/router, you can connect just using the one box. Either way, the PPP session will be dealt with by the Netgear. The settings you need are PPPoE, VLAN101, username homehub@btbroadband.com and password BT.
